Fritzbox 7050 meldet Fehler 503
Das ist ganz einfach:
telnet <ip des netgears>, also z.B.
telnet 192.168.1.0
Im DOS Fenster eingeben und fertig.
Frank
Wie du es beschreibst ja wenn eine fehlermeldung kommt ?!
So jetzt kommt:
VxWorks login:
Message Client Unable to connect to mail server
VxWorks login: admin
Password:
-> IGWLBFOGetWanMode Entry
IGWLBFOGetWanMode pLBFOWanMode->usBundleId: 1
IGWLBFOGetWanMode usLinkId: 1
IGWLBFOGetWanMode Exit
Message Client Unable to connect to mail server"
Es sieht so aus:
-> /config/algs>show
can't create output 'show'
errno = 0xd0001
-> FVX538: /config/algs>show
errno = 0xd0001
-> algs
undefined symbol: algs
-> cmd
undefined symbol: cmd
-> help
help Print this list
ioHelp Print I/O utilities help info
dbgHelp Print debugger help info
nfsHelp Print nfs help info
netHelp Print network help info
spyHelp Print task histogrammer help info
timexHelp Print execution timer help info
h [n] Print (or set) shell history
i [task] Summary of tasks' TCBs
ti task Complete info on TCB for task
sp adr,args... Spawn a task, pri=100, opt=0, stk=20000
taskSpawn name,pri,opt,stk,adr,args... Spawn a task
td task Delete a task
ts task Suspend a task
tr task Resume a task
d [adr[,nunits[,width]]] Display memory
m adr[,width] Modify memory
mRegs [reg[,task]] Modify a task's registers interactively
pc [task] Return task's program counter
Type <CR> to continue, Q<CR> to stop: ^
iam "user"[,"passwd"] Set user name and passwd
whoami Print user name
devs List devices
ld [syms[,noAbort][,"name"]] Load stdin, or file, into memory
(syms = add symbols to table:
-1 = none, 0 = globals, 1 = all)
lkup ["substr"] List symbols in system symbol table
lkAddr address List symbol table entries near address
checkStack [task] List task stack sizes and usage
printErrno value Print the name of a status value
period secs,adr,args... Spawn task to call function periodically
repeat n,adr,args... Spawn task to call function n times (0=forever)
version Print VxWorks version info, and boot line
NOTE: Arguments specifying 'task' can be either task ID or name.
value = 1 = 0x1
Ehh, ja. Nein. Was auch immer.
Keine Ahnung, was uns das sagen will. Vielleicht so eine Art Push Mail Service, der seine Mail nicht los wird.
Jetzt musst du nur noch der Anleitung von Gandalf folgen.
Frank
da hast du vollkommenen Käse eingegeben. Oh man, ich dachte, du kennst dich aus im EDV Sektor? :noidea:
Eingetippt hat gandalf94305 immer nur das, was rechts vom ">" steht. Du hast hingegen die ganze Zeile inkl. der Pfadangabe kopiert. :heul:
Das hier:
/config/algs
ist ein Pfad in der Telnet-Oberfläche, also eine Art Unterverzeichnis. Die hat gandalf94305 erreicht mit
cd config/algs
Dort hat er dann eingegeben
ls
und
show
und schließlich
disable <algname>
Letzteres für alle 3 SIP ALGs.
Frank
(werde es noch Editieren !!!)
In den Update steht:
Version 1.1.17
1. SIP ALG related issues.
Was heist das auf deutscht ?
Mein Log:
-> /config/algs
syntax error
-> config/algs
undefined symbol: config
syntax error
-> cd config/algs
Das
/config/algs/
gibst Du NICHT ein.
Gruß,
Wichard
-> cd /config/algs
undefined symbol: cd
Ähm ich habe sehr vieles versucht aber es geht nicht.
Nur mal so ne Idee, hat der Netgear vielleicht ein Port-Forward für Port 21 un der Telnet landet auf irgend einem Mail-Server?
Nein
Du bekommst gleich meine Port Vorwaarding Liste.
Hallo Frank
Super Tipp
Habe bei mir den STUN Eintrag gelöscht und jetzt funktioniert die Siemens Gigaset SX353 wieder normal
Gruss
Gérard
was für ein Branding hat die Fritzbox? Nicht alle Fritzboxen unterstützen automatisch jeden VoIP Anbieter, vor allem bei STUN gibt es Probleme. Nimm mal STUN raus aus der Konfig und auch mal den Proxy, so vorhanden.
Die Box kann ins Internet, also das IP-Setup ist korrekt? Überprüfe es ggf. im Telnet der Box.
Frank
crisu81
