Images Transparency Problem
gonys
19 Jan 2008
I have the problem with the writes of images in Mobile Customizer. How to save them without the background. Please help :confused:. I use PS CS2.
insufficent information in request.
;) ... how i can save images in PS CS2 to get transparent images in TC300 (ex. PC utylity icon, menu icons, smal phone icons etc.). Images will be converted in Mobile Customizer.
I test:
- PNG (8bit, 24bit with and without transparency)
- BMP (16bit)
Hi, if I understood well the images are 16 bit and sorry no transparency. If you want a transaprency effect your picture will need to look like it. Take care
...If you want a transaprency effect your picture will need to look like it...
like whot ?
- Menu icons have transparency
- Smool icons like antenna, PC Utylity, key blockade, etc.
I not understand why I can not do this? There is the tranparency option in the programme (Mobile Customizer).
This icons are transparent ! So, how to mede own with transparency :confused:
I not belief in this that can not do this.
Keine Mitglieder online.
Drago123
