Keine Eingehende Anrufe ab und zu Telekom Voip
the.neon
16 Mai 2006
Guten Tag ,
hab seit einer Woche ab un zu das immer morgens mich keiner Anrufen kann.
Im Log ist dann ein Forbidden , dachte erst es liegt an der DSL Trennung hab dann per cron ein "core reload" eingeplant .
Hat leider nichts gebracht :-(
sip.conf
[general]
registerattempts=0 ; Versuch es bis Sanktniemerleinstag
;defaultexpirey=240
maxexpirey=3600
defaultexpirey=3600
; Security
alwaysauthreject=yes
allowguest=yes
; FOP2
callevents=yes
context=from-sip-external
udpbindaddr=0.0.0.0
tcpenable=no
tcpbindaddr=0.0.0.0
transport=udp
srvlookup=yes
bindport=5160
language=de
externrefresh=600
maxexpiry=240
;allowguest=yes
;BLF
allowsubscribe=yes
notifyringing=yes
notifyhold=yes
limitonpeers=yes
register => xxx:Passwort:[email protected]/xxx
context=t-online_in
[external-standard](!)
trustrpid=no
nat=force_rport,comedia
directmedia=no
context=t-online_in
type=peer
insecure=port,invite
disallow=all
allow=ulaw
allow=alaw
dtmfmode=rfc2833
usereqphone=no
t38pt_udptl=no
[DTAG-IP](external-standard)
[email protected]
[email protected]
secret=Passwort
host=tel.t-online.de
fromdomain=tel.t-online.de
qualify=yes
Asterisk Messages :
[May 31 07:29:32] NOTICE[10000] chan_sip.c: Outbound Registration: Expiry for tel.t-online.de is 3600 sec (Scheduling reregistration in 3585 s)
[May 31 08:29:17] NOTICE[10000] chan_sip.c:    -- Re-registration for  [email protected]
[May 31 08:29:17] NOTICE[10000] chan_sip.c: Outbound Registration: Expiry for tel.t-online.de is 3600 sec (Scheduling reregistration in 3585 s)
[May 31 09:29:02] NOTICE[10000] chan_sip.c:    -- Re-registration for  [email protected]
[May 31 09:29:02] NOTICE[10000] chan_sip.c: Outbound Registration: Expiry for tel.t-online.de is 3600 sec (Scheduling reregistration in 3585 s)
[May 31 09:48:49] WARNING[10000][C-00000022] chan_sip.c: Received response: "Forbidden" from '"XXXXX" <sip:[email protected]>;tag=as7292f2dc'
[May 31 09:49:02] WARNING[10000][C-00000023] chan_sip.c: Received response: "Forbidden" from '"XXXXX" <sip:[email protected]>;tag=as1ebb13a1'
[May 31 09:52:52] WARNING[10000][C-00000026] chan_sip.c: Received response: "Forbidden" from '"XXXXX" <sip:[email protected]>;tag=as24cd70d9'
Hi ,
das hab ich für das forum nur so gemacht war die Telefonnummer mit Vorwahl.
Noch ein Nachtrag .
Es erscheint auch im Log :
May 31 09:59:15] WARNING[8014] chan_sip.c: !!! (config category='DTAG-IP_IN16_026' global force_rport='No' peer/user force_rport='Yes')
[May 31 09:59:15] WARNING[8014] chan_sip.c: !!! PLEASE NOTE: Setting 'nat' for a peer/user that differs from the  global setting can make
[May 31 09:59:15] WARNING[8014] chan_sip.c: !!! the name of that peer/user discoverable by an attacker. Replies for non-existent peers/users
[May 31 09:59:15] WARNING[8014] chan_sip.c: !!! will be sent to a different port than replies for an existing peer/user. If at all possible,
[May 31 09:59:15] WARNING[8014] chan_sip.c: !!! use the global 'nat' setting and do not set 'nat' per peer/user.
[May 31 09:59:15] WARNING[8014] chan_sip.c: !!! (config category='DTAG-IP_IN16_035' global force_rport='No' peer/user force_rport='Yes')
Bin mir nicht sicher ob diese Meldungen mit dem Problem was zu tun haben.
Ich glaube das liegt daran das der Anruf nicht über die IP reinkommt bei dem sich der Asterisk registriert hat. Das mit den Loadbalancern hast du ja scheinbar schon umgesetzt. Das "Forbidden" bekommst du vermutlich wenn du ausgehend telefonieren willst. Man möge mich korrigieren wenn ich falsch liege. Ich bekomme auch seit der Umstellung auf AllIP ab und an zu hören ich wäre telefonisch nicht erreichbar...
Hi ,
glaub ich auch das es ein Problem mit den Loadbalancer ist . Aber da kann doch nicht sein , das muss die Telekom doch richtig hinbekommen !?
Das Forbidden kommt bei einem eingehenden Anruf .
Hat jemand eine Lösung? Mach glaub mal ein Call bei der Telekom auf.
figo12
