SMC on Siemens SX541 : neue Version 2.11
snoopy78 schrieb:
habe auch gerade festgestellt, dass die letzte Aktualisierung meines SX-541 (FW 2.11 SMC) am 07.06.07 war.
Vorher hat es mit DYNDNS.ORG einwandfrei funktioniert, vermute daher dass dyndns.org etwas verändert hat, da die FW 2.11 schon seit längerer Zeit stabil läuft.
UPDATE
ok..hab grad mal den SX541 rebootet und er meldet mir auch
06/12/2007 16:51:19 NTP Date/Time updated.
08/01/2003 00:00:22 DDNS> Operation complete, DDNS IP=xx.xx.128.57
08/01/2003 00:00:21 If(PPPoE1) PPP connection ok !
hab natürlich auch gleich bei DYNDNS.org nachgeschaut...und siehe da
IP in Database/DNS: xx.xx.176.54
Last Updated: June 07, 2007 6:19:04 AM
New IP Address: xx.xx.128.57
sieht also wirklich so aus, als ob dyndns.org uns SX541 User ausgesperrt hat :(
naja habe bei dyndns.org mal ne supportanfrage aufgemacht [DYNDNS #442286]
ok.. hier die BLITZANTWORT von dyndns.org
Thank you for contacting our customer support team.
> I'm currently using an Siemens SX541 with SMC 2.11 Firmware as
> my internet connection.
> Since several days I and several other Siemens device (SX 541,
> SE 555, SE 515) users experiencing the problem, that our device
> is registering successfully at your service.
> The Log of my last connection:
> IP=xx.xx.128.57
> But at your Website i can see that the new IP isn't stored.
> Can you please tell me how we can get the Service working again.
We have not made any changes that should affect your router's ability to
update. If your router is unable to properly update your IP address it
means that its update client was created incorrectly. Our update
guidelines are displayed on our website so that anyone can create an
update client to work with our systems. If yours does not, it means that
they did not create it correctly. You will need to contact the
manufacturer for help. Here is the information on our update API:
http://www.dyndns.com/developers/specs/
danach ging noch folgende mail an den support raus (incl. deren antwort)
> if you PLEASE read my mail carefully you will realize that i'm using
> exactely this router & configuration for several months right now.
> Also the LOG shows that the router is updating successfully.
> PLEASE check out if there is not an bug or "small" glitch in your
> system.
I did carefully read your email and am acknowledging that it was working
for you for the past few months. As I stated in my email we have not
made any changes that should affect your router's ability to update if
it was designed with our specifications. If it is failing to update that
means that it was not designed correctly. We have made it easy for
developers to get the information necessary to create a compliant update
client. It sounds like they have failed to do so. You must contact them
for help as we did not design the update client that you are using.
ok.. anfrage an smc ging auch gerade raus :D
hmmm.....komisch.. jetzt geht es wieder ?
IP in Database/DNS: xx.xx.148.141
Last Updated: June 12, 2007 4:38:10 PM
06/12/2007 21:38:10 DDNS> Operation complete, DDNS IP=xx.xx.148.141
Changelog????????
Cau Adas
ööööhmmm....
snoopy78 schrieb:
hey hey...
neue BETA 2.12 (leider noch keine RL notes)
@snoopy78: cool! Danke! Läuft die bei dir stabil? Ich hab irgendwie immer noch Probleme mit WPA und mehreren Clients. N Kumpel kickt mich mit seinem Notebook immer raus :/
Vllt wirds ja in dieser Version behoben :)
hallo,
also bei mir gehen bis jetzt mein Notebook, die Wii und mein N80 OHNE Probleme mit WPA/WPA2 ins Netz...
sieht auch sonst BISHER sauber aus :D
Jo cool. Hab dir mir auch mal gerade draufgepackt. Mal sehn
hab da mal ne frage
und zwar was für ein vorteil bringt die smc firmware auf dem sx541 ?
Die Möglichkeiten der Hardware werden von der SMC-Firmware meistens besser ausgenutzt und sind feiner konfigurierbar als bei der Siemens-Firmware, z.B. kann man festlegen, dass für VoIP immer ein gewisser Anteil der Bandbreite reserviert wird, damit man nicht Qualitätsprobleme bei der Gesprächsübertragung bekommt, wenn man gleichzeitig viel DSL-Datenverkehr laufen hat.
Aber es gibt auch Nachteile, z.B. ist die Firmware nur auf englisch verfügbar, man kann keine feste Ortsvorwahl einkonfigurieren, ...
hat eigentlich niemand probleme mit der 2.12? bzw.1.69...musste wieder die 2.09 drauf machen den das ist die einzigste die bei mir 24/7 funzt!!!
ja und, was ist jetzt dein Problem ?
neuer ist nich immer besser
bei mir geht alles mit der Aktuellen. Ich klau auch nix aus dem Internet ;)
Ich klau auch nix aus dem Internet????? wie soll ich das jetzt verstehen?
überigends hab ich kein problem!! sondern wollte nur wissen obs jemanden genau so geht!
edit:jetzt weiß ich was du meinst!!na aber für das kennst dich dann aber gut aus ;) solltest dann aber auch wissen das es legales gibt! oder geht der mensch von sich selber aus? ;)
Seit heute Nacht steht eine FW-ISDN_2.12bin Version bei Solcon bereit. Ist die Betaversion wohl erwachsen geworden ;) . Die Beta gibts dort aber auch noch. Hat sich scheinbar nichts geändert.
INFORMATION
Numbers of DHCP Clients: 0
Runtime Code Version:
2.12 (May 23 2007 17:15:55)
Boot Code Version: 0.69d.0
ADSL Modem Code Version: 07.00.04.00B
Die zwei Dateien sind identisch.
Cau Adas
flashen ganz normal über web-gui?
hat jemand ein bild von der oberfläche wäre super danke !
habe versucht die 2.12 aufzuspielen via web-oberfläche
jetzt startet nur noch das:
Recovering Tool
This tool allows you to upgrade the gateway's system firmware using a file provided by the vendor.
Enter the path and name of the upgrade file then click the APPLY button below. You will be prompted to confirm the upgrade.
Upgrade Target:
Runtime Code
Boot Loader
wenn ich nun die 2.12 auswähle zum upgrade, erhalte ich einen error
geht mit der 2.12 firmware nun VoIp hinter einem router?
habe es auf die schnelle nicht hinbekommen :
registration sip fail
Kann mir bitte einer sagen wo ich die SMC Firmware 2.12 runterladen kann? Also die Version die hier in Deutschland (Annex B) funktioniert. Oder ist die Version die hier weiter oben verlinkt wurde, die richtige Version? Danke
Almgandhi
