Zyxel 2002 problems mit Motorola SB5101e
babo
6 Jul 2006
Sorry but my Deutch is bad so I will write in English
I have regular adsl connection, but my zyxel 2002 ATA doesn't connect to it,
ADSL is on Motorola surfboard 5101e,im going trough PPPoE on cabel operator
on SYSTEM STATUS it says:
Ethernet Port:
IP Address : 0.0.0.0
IP Subnet Mask : 0.0.0.0
I don't know what to try to fix it manual
Ethernet TCP/IP Settings
+Get IP Address Automatically
Use fixed IP address
if I use fixed IP it still doesn't work
my username and passw are OK
It should connect itself automaticly but it eams to me that it doesn't
Yes I'm on default settings
Model Name : Prestige 2002
ZyNOS Firmware Version: V3.60(MD.2) | 11/09/2004
I tried to find similar problems hier in forum but I dont undertand everything
Thanx for help in advanced
VoIP status :
SIP1
SIP Registration Status : Register fail
Used Port : 5060/UDP
sorry for my bad English.
first get a new Firnware on your Zyxel.
your FW is very old.
second put your Zyxel in the DMZ of your Router and use fix IP Adresses.
By Verona
I don't understand DMZ, what is that?
"second put your Zyxel in the DMZ of your Router and use fix IP Adresses."
I will download this FW
P-2002 3.60(MD.4)C0 N/A 08-30-2005
It is funny becouse it worked well with simens adls modem, it was on "get automatic IP" and it found it got IPs by itself and I could use telephone
Please explain me DMZ
thnx
I'm connected troug cableTV operator
cable=> motorola SB5101e modem=> ZYXEL 2002=> laptop (optional)
ZyNOS Firmware Version: V3.60(MD.4) | 08/22/2005
Routing Protocols : IP
Ethernet Port:
Mgnt Port
IP Address : 192.168.5.1
IP Subnet Mask : 255.255.255.0
VoIP status :
SIP1
SIP2
SIP Registration Status : Not Register
When I press Register button it says>
Status: Can't find the Autentication user!!
I want to use it without a computer,
cable=> motorola SB5101e modem=> ZYXEL 2002 => telephone
Power down your Motorola cabel modem for a few time,
then it is possibel that your cabel prowider do not rennew the MAC adress of the Zyxel.
By Verona
After I upgraded the FW it just beeps, it's not ready to make phonecall, even if I dial a number it's still beeping
I tried shuting down the motorola modem, but since it's beeping it makes no change
I followed the instructions on
http://www.cormain.com.au/kb/viewtopic.php?t=17&sid=7bea4cb555ffcc87b305e72766fa00e5
what is the diffrence fro regular firmware and ENGINE ONLY
I even activated the STUN and tried few versions from
http://www.ip-phone-forum.de/showthread.php?t=89531
but it just beeps
I dont know is it now just not working from the FW or something else
Is it OK to beep beep all the time, (maybe becouse it's not connected to voipstunt),
becouse with old FW it it had constant tone when you first pick up the phone, and then when you dial the number it beeped beeped constantly
I'm worried that the FW is not ok
linus1991
